[GRASS-dev] [GRASS GIS] #331: extend the vector modell to be able
to calculate
real circular segments and circles => for calculating real
circular buffers of points
trac at osgeo.org
Fri Oct 10 18:24:18 EDT 2008
#331: extend the vector modell to be able to calculate real circular segments and
circles => for calculating real circular buffers of points
Reporter: mlechner | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: unspecified
Keywords: vector model curve circle buffer | Platform: Unspecified
Cpu: Unspecified |
It would be interesting to extend the grass vector model to be able to
construct curves for using them to create real circular buffers instead of
approximating them using several vertices.
I just was wondering - isn't it more effectice saving a buffer using one
vertice and a "curved line" than using several points and approximate the
circle.
An appproximated buffer could still be in the data - only newly calculated
buffers are more correct then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/331>
