[GRASS-dev] g.mlist syntax vs g.mremove syntax
Markus Neteler
neteler at osgeo.org
Tue Oct 14 06:21:04 EDT 2008
this syntax is easy to remember:
g.mremove rast=gpcp_1dd_p1d.*.* [-f]
while
g.list type=rast
g.mlist type=rast pattern=gpcp_1dd_p1d.*.*
is less so.
Certainly this works
g.list rast
g.mlist rast pattern=gpcp_1dd_p1d.*.*
however, the syntax behind is more complicated than
for g.[m]remove.
Can we simplify to
g.mlist rast=gpcp_1dd_p1d.*.*
in GRASS 7?
(In the same moment, maybe merge g.list and g.mlist?)
Markus
