[GRASS-dev] Re: mapsets and locations with spaces on wingrass?
Markus Neteler neteler at osgeo.org
Wed Oct 15 09:24:02 EDT 2008
On Wed, Oct 15, 2008 at 2:03 PM, andrea antonello
<andrea.antonello at gmail.com> wrote:
(previous mail)
The code in question for the CLI startup is in
lib/init/set_data.c
Perhaps some quoting is missing there (I also see short name buffers there
and such).
> Ok, found the following:
> "If installed into a directory that has spaces in either its name or
> the path of directories leading up to it, some functionalities of
> GRASS might be hampered. We would highly appreciate if you tried and
> reported any problems, so that we can fix them. "
> I suppose that this means that usually at least it can be started, right?
I think you can with command line startup.
I tried
> Is there a list of the hampered functionalities?
I am afraid no. But myself, I used it for weeks with a white space in the
path name, it worked (say, we fixed a couple of things in those days).
So, in the path to the GRASS database including that is might be ok,
but apparently not yet in a location name.
Markus
> Launching commands from the JGrass prepared environment I get an error
> telling that the filename is illegal because of the < > character,
> which I assume being the space. So the maps are not found and the
> command is not launched.
> Any idea on this?
> Andrea
> On Wed, Oct 15, 2008 at 1:22 PM, andrea antonello
>> Hi developers,
>> I browsed the native grass package Known Issues, but couldn't find an answer.
>> Does grass on windows have problems with spaces in the mapset or location path?
>> I tried to launch the console mode and it seems to accept the "test
>> location" and "test mapset" entries.
>> When I then do ESC-ENTER, it proposes me to create the mapset "test",
>> which means it doesn't take the full path.
>> Thanks,
>> Andrea
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
