[GRASS-dev] Re: [GRASS-SVN] r33673 - in grass/trunk/raster: . r.statistics2
Hamish hamish_b at yahoo.com
Sun Oct 19 00:17:59 EDT 2008
Glynn Clements wrote:
> I have no idea how you would compute diversity or mode for FP data
> (other than by sorting the entire set of values), or if this is even
> meaningful (if the values are physical quantities, then in the absence
> of rounding due to limited measuring precision, each value should
> theoretically be unique).
The quick answer is that you can't calculate diversity or mode for FP data
without depending on the quirks of FP precision or generalizing into
quantiles.
A more abstract answer is that you can, if you consider peaks in the
histogram, (like a gas chromatograph plot or radiance absorption peaks in
satellite imagery). A bimodal distribution would be more diverse than a
simple Gaussian bell curve, etc. Spike with the biggest area under it would
be the mode?(??) Again there is the issue of quantile limits: how wide is a
real spike vs. what is sampling noise? what constitutes the spike vs
bump threshold?
just an idea,
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
