[GRASS-dev] Re: [GRASS GIS] #339: d.mon doesn't work (WinGrass
commandline)
trac at osgeo.org
Sun Oct 19 07:45:17 EDT 2008
#339: d.mon doesn't work (WinGrass commandline)
Reporter: schulzea | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0 RCs
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:2 schulzea]:
> okay, not so nice.
> Are there plans to include x monitors in WinGrass or is this not
possible?
We never managed to figure out how to create a socket which works with
read() and write(), and changing the code to use Windows-specific
equivalents was too much work. In 7.0, monitors have been removed
entirely.
> It is pretty annoying to run the script under WinGrass commandline and
then have to change to WinGrass GUI to see the results.
> Or is there a possibility to use the shell in the GUI-version
You should be able to start a command-line session then start the GUI with
g.gui. Or look for an image viewer which has an option to automatically
re-load the file if it is modified, and use it to view the map.png file
created by d.* commands.
Ticket URL: <http://trac.osgeo.org/grass/ticket/339#comment:3>
