[GRASS-dev] Re: [GRASS GIS] #339: d.mon doesn't work (WinGrass commandline)
GRASS GIS trac at osgeo.org
Sun Oct 19 08:21:16 EDT 2008
  Reporter:  schulzea      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  closed
  Priority:  major         |   Milestone:  6.4.0
 Component:  default       |     Version:  6.3.0 RCs
Resolution:  fixed         |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:1 hamish]:
 > X monitors do not exist in native MS windows. You must use the GUI or
 install the cygwin version.
 > Perhaps an #ifdef could be added to d.mon so the module reports
 something to this effect rather than leave the user confused.
 It might be better to just omit d.mon on Windows. The program itself
 compiles fine, but as none of the drivers exist, there isn't much point in
 d.mon existing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/339#comment:5>
