[GRASS-dev] Re: [GRASS GIS] #340: d.labels doesn't place labels
exactly on coordinate point in label file.
trac at osgeo.org
Mon Oct 20 05:03:07 EDT 2008
#340: d.labels doesn't place labels exactly on coordinate point in label file.
Reporter: wolf | Owner: hamish
Type: enhancement | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Comment (by hamish):
do I have this right?
d.labels: patch skips adjustments for dealing with multi-line labels
(desired?), and puts bottom left corner of text box at the exact
coordinate.
like:
_____________
.|_text here_|
ps.map: just like LOWER,LEFT placement but without any X,Y_just_offset
which keeps the label off of the symbol.
I would prefer, in this order:
- use ref: center,center as the basis for offsets
- ref: bottom_0,left_0 instead of none,none to indicate where + no
padding.
If it can be done with "ref: center,center" I'd be a lot happier.
some other points:
- I would not move the above rendering offsets into v.label.
- From the user's perspective I'd think they'd expect SA placement to be
an optional flag of v.label. Codewise that may be harder, but I am just
speaking about what a user might expect and long term goals.
- I do not have plans to replace v.label with v.label.sa. For one thing
v.label has had some fixes after v.label.sa forked which AFAIK have not
been ported (mostly to do with correctly handling rotation). I suspect
there are a few other small things.
- v.label does not sort smallest label on top, nor (by default) IMO
should it. Fine for SA, but isn't the whole point of SA that they not
overlap in the first place, so not an issue?. See related filled-area
"v.bubbleplot" for/against discussions to sort points to put smallest
circles on top.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/340#comment:3>
