[GRASS-dev] convergence angle
Hamish
hamish_b at yahoo.com
Tue Oct 21 06:11:42 EDT 2008
was: [GRASS-dev] porting r.in.wms to python
wrt: angle between grid north and true north
> Hamish wrote:
> > does anyone know of a libgis function that will return
> > the current projection+coordinate's convergence angle WRT true north?
> > A method to find that with the `proj` program is given here:
> http://grass.osgeo.org/wiki/Ps.map_scripts#Creating_a_fancy_North_Arrow
Glynn:
> The -V option is handled by vprocess() in proj.c (in PROJ); after
> converting to/from lat/lon, it basically just calls pj_factors() (in
> pj_factors.c) then prints out all of the values.
> The following code (from r.proj) will get you the "struct pj_info" for
> the current location.
> struct pj_info oproj;
> /* Get projection info for output mapset */
> if ((out_proj_info = G_get_projinfo()) == NULL)
> G_fatal_error(_("Unable to get projection info of output raster map"));
> if ((out_unit_info = G_get_projunits()) == NULL)
> G_fatal_error(_("Unable to get projection units of output raster map"));
> if (pj_get_kv(&oproj, out_proj_info, out_unit_info) < 0)
> G_fatal_error(_("Unable to get projection key values of output raster map"));
> The "pj" field (i.e. oproj.pj) is the projPJ* which the PROJ library
> wants. You should then be able to use pj_factors() directly to get the
> convergence angle, e.g.:
> LP lp = { <lat, long> };
> struct FACTORS fact;
> pj_factors(lp, oproj.pj, 0.0, &fac);
> convergence = fac.conv;
I am trying to add this as "g.region -n" now, some questions:
1) local_proto.h: what's next in this series:
#define PRINT_REG 0x01
#define PRINT_SH 0x02
#define PRINT_LL 0x04
#define PRINT_EXTENT 0x08
#define PRINT_CENTER 0x10
#define PRINT_METERS 0x20
#define PRINT_3D 0x40
#define PRINT_MBBOX 0x80
#define PRINT_NANGLE 0x ???
2) #include <projects.h> to get LP, FACTOR, and pj_factors() ?
3) The compiler complains that arg 2 of pj_factors(, oproj.pj,) is of
an incompatible pointer type. If I make it *oproj.pj it doesn't complain
but the output fact.conv is always 0.00000.
thanks,
Hamish
