[GRASS-dev] Addons: r.sun2 segfault
Glynn Clements
glynn at gclements.plus.com
Tue Oct 21 17:54:58 EDT 2008
Markus Neteler wrote:
> Working on a large DEM, r.sun2 (addons) segfaults for me:
> #0 INPUT_part (offset=0, zmax=0x7fffc45840a8) at main.c:965
> #1 0x0000000000405d6e in calculate (singleSlope=<value optimized out>, singleAspect=<value optimized out>,
> singleAlbedo=<value optimized out>, singleLinke=<value optimized out>,
> As so often, I get lost in the gdb output :)
Start by compiling without optimisation. If optimisation is enabled,
you still get a backtrace, but real debugging becomes practically
impossible, as the compiled code typically bears little or no
resemblance to the source code.
However, looking at the numbers:
horizonarray = malloc(arrayNumInt * numRows * n);
m = cellhd.rows = 19509
n = cellhd.cols = 23522
horizonStep = 15
arrayNumInt = 360 / horizonStep = 360/15 = 24
numPartitions = 1
numRows = m / numPartitions = 19509 / 1 = 19509
arrayNumInt * numRows * n = 24 * 19509 * 23522 = 11,013,376,752
So the horizon array works out at ~11GB. Personally, I would start by
checking that horizonarray is non-null (note that it uses malloc(),
not G_malloc(), so there's no error checking).
But more generally, there are so many things wrong with that code that
dealing with specific bugs is just papering over the cracks.
