[GRASS-dev] [GRASS GIS] #344: TODO: move high priority incubated
modules into main
trac at osgeo.org
Wed Oct 22 05:28:42 EDT 2008
#344: TODO: move high priority incubated modules into main
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
before 6.4.0 we should move high priority incubated modules into main. For
replacements, if the svn-addons still has issues which makes it poorer
than the old version, we can call it "g.module2",
otherwise we replace. If still known to be beta-ware but still functional
we can add a G_warning() to the beginning of the module as an absolution.
Just having a quick look through
https://trac.osgeo.org/grass/browser/grass-addons
Modules to consider:
d.frame.split?
r.colors.stddev?
r.viewshed
r.sun2+horizon
r.watershed2
v.buffer2
v.colors?
v.delaunay2
v.parallel2?
v.out.ascii.db -> v.out.ascii C code !!
r.pack rewrite using method similar to r.convert (#84) + tar.gzip?
put together a quick v.to.3d wrapper script?
others?/add?/remove?/replacement or "g.module2"?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344>
