[GRASS-dev] Re: [GRASS GIS] #338: d.vect / v.univar does not
work for layer > 1 ; v.db.join has bugs (corrected here)
Glynn Clements
glynn at gclements.plus.com
Wed Oct 22 11:45:58 EDT 2008
Moritz Lennert wrote:
> > > 2) v.db.join: The layer option was missing in v.db.addcol and, in
> > db.execute, 'driver' and 'database' options were missing thus breaking it
> > for layer > 1
> > Fixed in Revision 33971.
> I would like to port this to grass7. Does attached diff look correct
> (seems straightforward, but no experience with python scripting, yet, so
> just making sure) ?
> - if grass.run_command('v.db.addcol', map = map, columns = colspec) != 0:
> + if grass.run_command('v.db.addcol', map = map, columns = colspec, layer = layer) != 0:
This looks okay.
> stmt = template.substitute(table = maptable, column = column,
> otable = otable, ocolumn = ocolumn,
> - colname = colname)
> + colname = colname, database = database, driver = driver)
This won't do anything, as the template doesn't contain substitutions
for $database and $driver. Nor can they be added, as the template is
just the SQL statement. The database and driver would need to be
passed to db.execute, e.g.:
- if grass.write_command('db.execute', stdin = stmt) != 0:
+ if grass.write_command('db.execute', stdin = stmt, database = database, driver = driver) != 0:
