[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Fri Oct 24 22:42:55 EDT 2008
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
[keep it in the bug report please!]
> > Comment (by neteler):
> > what about integrating your fixes from
http://markus.metz.giswork.googlepages.com/r.out.gdal.conservative.tar.gz
Markus Metz wrote:
> Sure, no objections from my side, I'm using this version only. But
> r.out.gdal is a very important module of GRASS and maybe some more
> testing is required. Also, the new features may not find approval by
> all,
yep
> e.g. I've put in rather restrictive NULL cell handling: the user
> has to specify a nodata value that falls within the range of the
> selected datatype (Byte, UInt16, Int16, ...), a nodata value is no
> longer chosen automatically as in the original version. If a nodata
> value is not given, but NULL cells are present, r.out.gdal aborts with
> an error message.
When possible, I think it better to have a sensible default then give the
user the option to override. That's what we have in the existing code.
NULL=max possible is a common usage, so not bad for a default. Your change
is too conservative for my vote, and generally I don't like banning users
from doing things just because my imagination is limited as to why they
would want to do something funny. If they really want to set nodata=
out of bounds, and explicitly give a nodata= value specifying that, I'd
say let them (with a warning in case they didn't realize, of course).
> My version also no longer uses the current region resolution, instead
> the current region extends are aligned to the resolution of the raster
> to be exported to avoid any implicit resampling.
Nope. I see your reasons, but this is in violation of GRASS's standard
raster semantics, and one of the reasons for the r.out.gdal.sh ->
r.out.gdal (.c) was to "fix" this. (sort of)
Maybe it makes the GRASS<->R stats people happier?, but shouldn't be the
default method, and I doubt offered at all. I would think this better
handled with a note in the help page with a suggestion to use
"g.region res=.. -a" if they want that.
> And the colortable is only exported on request, and then with a warning
> message.
IMO that should be automatic with Byte maps (255 levels), perhaps needed
with UInt16 maps (with 65535 levels) it should be optional...
> If these changes are ok with you then integrate the changes, otherwise
> maybe only some, but not all changes could be integrated. More
> discussion needed on how to change/improve r.out.gdal?
as above. I need to reread the (long) bug history now, but fwiw I just
fixed
yesterday a bug in SVN where nodata= value given by the user was only
used if type= was also given, otherwise the auto-type determination reset
it.
I also noticed that QGIS 0.8.1 (old, but latest debianGIS package for
Etch/stable) has a bug where the first palette entry always is black,
even when the GeoTIFF says otherwise. (loads/views fine in other software)
In my case it was a 7-color palette with cat 0 being white in the color
table.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/73#comment:17>
