[GRASS-dev] Re: i.modis.qc
Glynn Clements
glynn at gclements.plus.com
Sun Oct 26 11:00:04 EDT 2008
Yann Chemin wrote:
> maybe it is wiser indeed to change to ">>=" for platform/compiler
> stability as it forces the variable to be updated.
> Somehow it is not necessary on my system (Debian/Sid).
If you want to modify the variable, you need to use >>=. >> just
returns the shifted value, which is pointless in this particular case.
A statement like:
x >> 1;
makes no more sense than:
x + 1;
or:
x * 2;
There's no point evaluating an expression unless you're going to do
something with the result, e.g. assign it to a variable, or pass it to
a function which will make use of it.
If you aren't getting warnings, that's probably because your CFLAGS
doesn't include -Wall or similar. The expression is perfectly valid C,
so you won't get a warning by default. -Wall enables various optional
warnings, including warnings for code which is valid but which might
not do what you expect (e.g. "if (x = 0) ..." is valid, but it's more
likely to be a typo for "if (x == 0) ...").
However, there is still the question of which variable should be
updated. E.g. in qc250b():
qctemp >> 2; /*bits [2-3] become [0-1] */
qctemp = pixel & 0x03;
Changing this to >>=:
qctemp >>= 2; /*bits [2-3] become [0-1] */
is equally pointless, as you would be modifying qctemp then
immediately discarding the modified value. Both of the above versions
are equivalent to just:
Which leads me to suspect that it's "pixel" which should have been
shifted, not qctemp.
If you don't understand what this code is supposed to do, please
remove it. I don't understand what it's supposed to do either, so I
can only notice things which are obvious mistakes, not anything which
*could* plausibly be correct but actually isn't.
