[GRASS-dev] Re: [GRASS-stats] Re: [R-sig-Geo] writing shapefiles
/ DBF files when input data contains NA
Markus Neteler
neteler at osgeo.org
Wed Oct 29 06:00:10 EDT 2008
On Tue, Oct 14, 2008 at 11:13 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Oct 14, 2008 at 8:59 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> On Mon, 13 Oct 2008, Dylan Beaudette wrote:
>>> Have the changes in the rgdal package made it into the mainstream code? I
>>> have submitted tickets to the GRASS trac site for the v.out.ogr patch. The
>>> changes you suggested appear to work well.
>> No sign of any change in the 6.3 or 6.4 trunks, unfortunately. 7.0 has the
>> same bug. No response to the posting or your tickets. The only relevant
>> thread was Markus' suggesting a name change in 7.0. Hamish: could you please
>> prod the person(s) needed to move on ticket 333, and get them to do the same
>> on 6.4 and 7.0 (the patch is for 6.3)?
> I have fixed trax #333 now with minor modification (C++ style comments
> are no good).
> Applied to 6.3.svn, 6.4.svn, 7.svn.
Sorry, discovered only now that the 6.4.svn fix was uncommitted on my
laptop. Submitted as revision 34049, unfortunately with wrong ticket
reference.
So, now this issue should be really solved.
Markus
