[GRASS-dev] Re: [GRASS GIS] #350: build_html_index.sh: put photo
modules in imagery section
trac at osgeo.org
Wed Oct 29 17:20:20 EDT 2008
#350: build_html_index.sh: put photo modules in imagery section
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: minor | Milestone: 6.4.0
Component: Docs | Version: svn-develbranch6
Resolution: | Keywords: man help build
Platform: All | Cpu: All
Comment (by glynn):
Replying to [ticket:350 hamish]:
> the photo.* modules should be listed at the end of the imagery module
section in imagery.html and full_index.html.
> I'm not sure how to do that..
The build_html_index.sh iterates over prefixes, generating one HTML file
for each prefix. You would need to significantly change the script to
allow multiple prefixes in a single HTML file.
In any case, I'm not sure that these modules should even appear in the
index, as they're only usable via i.ortho.photo. IMHO, the indices should
only list user-visible modules in $GISBASE/bin and $GISBASE/scripts, not
the utility modules in $GISBASE/etc. The latter should be referenced from
the manual of the module(s) which invoke them.
Ticket URL: <https://trac.osgeo.org/grass/ticket/350#comment:1>
