[GRASS-dev] Re: [GRASS GIS] #349: v.out.gpsbabel
trac at osgeo.org
Thu Oct 30 03:30:20 EDT 2008
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords: gpsbabel gpx export
Platform: All | Cpu: All
Comment (by neteler):
ogr2ogr with GRASS plugin seems to do something for GPX:
ogr2ogr -f "GPX" /tmp/roads.gpx
/home/neteler/grassdata/latlong/PERMANENT/vector/roads/head
Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
/home/neteler/grass64/dist.x86_64-unknown-linux-gnu
ERROR 6: Field of name 'cat' is not supported in GPX schema. Use
GPX_USE_EXTENSIONS creation option to allow use of the <extensions>
element.
ERROR 6: Field of name 'FNODE_' is not supported in GPX schema. Use
element.
ERROR 6: Field of name 'TNODE_' is not supported in GPX schema. Use
element.
ERROR 6: Field of name 'LPOLY_' is not supported in GPX schema. Use
element.
head /tmp/roads.gpx
<?xml version="1.0"?>
<gpx version="1.1" creator="GDAL 1.6.0dev"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://www.topografix.com/GPX/1/1"
xsi:schemaLocation="http://www.topografix.com/GPX/1/1
http://www.topografix.com/GPX/1/1/gpx.xsd">
<rte>
<rtept lat="46.496014615508486" lon="11.787510530727392">
<ele>0.000000</ele>
</rtept>
<rtept lat="46.496068936543473" lon="11.788050878137794">
<ele>0.000000</ele>
</rtept>
<rtept lat="46.496084453543688" lon="11.788152669713275">
tail /tmp/roads.gpx
</rte>
<rte>
<rtept lat="45.836343018280424" lon="11.010669506900909">
<ele>0.000000</ele>
</rtept>
<rtept lat="45.836339313174427" lon="11.010664663523668">
<ele>0.000000</ele>
</rtept>
</rte>
</gpx>
I didn't check what GPX_USE_EXTENSIONS does but probably a simple
shell/python wrapper to ogr2ogr would do the job.
Markus
Ticket URL: <https://trac.osgeo.org/grass/ticket/349#comment:2>
