[GRASS-dev] simwe
Glynn Clements
glynn at gclements.plus.com
Thu Oct 30 14:17:30 EDT 2008
Helena Mitasova wrote:
> I have commented out the sites-related input/output from simwe in trunk.
> It compiles and runs with grass7 updated today - I tested it with the
> examples from grassbook and some variations of the parameters.
> Are these changes enough to get it back into grass7?
> (there is still the issue of 3 separate waterglobs.h - I need to talk
> to Jaro to see what would be the best way to fix it).
I suggest committing the changes, but leaving it disabled in
raster/Makefile until the sites and waterglobs.h issues have been
fully dealt with.
If you keep a private copy around for too long, it may become
problematic to merge it if the SVN copy gets modified in the meantime
(if I'm making changes related to a particular header file or a
particular function, I'll normally change everything which uses it,
even modules which are disabled).
Regarding waterglobs.h, does it work if you remove
r.sim.*/waterglobs.h and add -I../simlib to EXTRA_CFLAGS in
r.sim.*/Makefile? Or are there other issues?
> Also, should I submit these changes to GRASS64 so that it runs in
> winGRASS? (I am not sure what was the problem there)
I'd suggest leaving it for now. The version in 6.4 isn't as likely to
be modified as in 7.0.
