[GRASS-dev] Re: [GRASS GIS] #352: r.in.gdal region troubles in LL
trac at osgeo.org
Fri Oct 31 02:23:16 EDT 2008
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
* cc: Agustin.Lobo at ija.csic.es (added)
Comment:
Replying to [comment:1 glynn]:
> Replying to [ticket:352 neteler]:
> > gdalinfo npp.tif
> > Pixel Size = (0.250000000000200,-0.250000000000200)
> It's that extra 0.0000000000002 that's causing the problems:
I see.
> [And which will forever cause problems. We'll just have to work around
them as we find them. Almost everything that you "know" about coordinate
geometry is wrong for spherical geometry. E.g. just because x1 == x2, that
doesn't mean that x1-x0 == x2-x0.]
The user took this map
http://user.uni-
frankfurt.de/~grieser/downloads/NetPrimaryProduction/npp_CruP_All_fine_geo.zip
and passed it to R, and then redefined:
>b <- npp_geotiff
>b at data$band1[b at data$band1 <0 ]<- 0
and then he wrote b as npp.tif using the QGIS plugin manageR.
(Source: http://lists.osgeo.org/pipermail/grass-user/2008-
October/047211.html)
Maybe there is a precision issue before, somwhere in the R or QGIS part?
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/352#comment:2>
