[GRASS-dev] Re: [GRASS GIS] #268: the "command layer" in wxGUI does not work
GRASS GIS trac at osgeo.org
Mon Sep 1 06:48:37 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by martinl):
  * status:  reopened => new
  * owner:  grass-dev at lists.osgeo.org => martinl
 * cc: grass-dev at lists.osgeo.org (added)
Comment:
 Replying to [comment:3 msieczka]:
 > Ahh, this takes place only when autorendering is enabled.
 Right, fixed in devbr6 (r33185) and trunk (r33186). Command layer is
 rendered on enter key event not when command is changed. It's also
 possible to enter multiple commands separated by ';'. It required some
 changes in render engine, so please test.
Ticket URL: <http://trac.osgeo.org/grass/ticket/268#comment:4>
