[GRASS-dev] [GRASS GIS] #274: vdigit: cursor and vertex are apart when moving vertices
GRASS GIS trac at osgeo.org
Wed Sep 3 14:35:44 EDT 2008
 Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.0
Component:  default   |     Version:  svn-develbranch6
 Keywords:            |    Platform:  All
      Cpu:  All       |
 develbranch6 r33238
 Simple example:
 1. Digitize a single line with 2 nodes.
 2. Choose "Move vertex" tool.
 3. Hover over a node, select it with the left button and, before 0.5 a
 second passes, move mouse very quickly.
 The vertex and cursor become apart (the distance between them depend on
 how promptly and quickly you moved the mouse). Pressing the right button
 to confirm the placement, behaves like if the middle button was pressed
 actually - the edit is cancelled.
 Weird. Looks like if vdigit needs few tens of a second brake between
 activating the tool and using it. Fixable?
Ticket URL: <http://trac.osgeo.org/grass/ticket/274>
