[GRASS-dev] Re: [GRASS GIS] #277: Query vector map (edit mode): does not work
GRASS GIS trac at osgeo.org
Thu Sep 4 09:58:06 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by martinl):
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => martinl
 * cc: grass-dev at lists.osgeo.org (added)
Comment:
 I guess you are refering to area querying (i.e. querying primitives like
 points, lines, boundaries or centroids should work). I fixed that in
 r33249.
 Anyway please not that querying vector maps (display or edit mode) is
 quite slow. Module v.what builds always spatial index. This should be
 changed, optionally to read spatial index information from file (TODO for
 GRASS7 or GRASS 6.5).
Ticket URL: <http://trac.osgeo.org/grass/ticket/277#comment:1>
