[GRASS-dev] [GRASS GIS] #287: vdigit: don't force 'cat' as the key
column name
trac at osgeo.org
Sat Sep 6 05:09:46 EDT 2008
#287: vdigit: don't force 'cat' as the key column name
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
r33285
When a new vector map is created in vdigit, it forces 'cat' as the key
column name. This is not really bad, and very common in other GRASS
modules, but I think it should be possible to specify a custom key column
name in any module that creates a vector map with a linked table.
Ticket URL: <http://trac.osgeo.org/grass/ticket/287>
