[GRASS-dev] Re: [GRASS GIS] #287: vdigit: don't force 'cat' as the key column name
GRASS GIS trac at osgeo.org
Sat Sep 6 05:33:50 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  minor     |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by msieczka):
  * component:  wxGUI => default
Comment:
 Replying to [comment:1 martinl]:
 > You can change default key column in GUI Preferences ("Attributes" tab).
 Cool, but that's not the same thing. I mean, that, ideally, the key column
 setting should be adjustable ad command run time, too (this issue is not
 limited to vdigit actually).
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:2>
