[GRASS-dev] Re: [GRASS GIS] #287: vdigit: don't force 'cat' as the
key column name
trac at osgeo.org
Sat Sep 6 06:35:54 EDT 2008
#287: vdigit: don't force 'cat' as the key column name
Reporter: msieczka | Owner: martinl
Type: defect | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by msieczka):
Replying to [comment:3 martinl]:
> Replying to [comment:2 msieczka]:
> > Cool, but that's not the same thing. I mean, that, ideally, the key
column setting should be adjustable ad command run time, too (this issue
is not limited to vdigit actually).
> Not only vdigit, also creating vector map layer from main menu
('Vector->Develop vector map->Create new vector map').
I know.
> Do you mean to use GIS/environment variable like GRASS_KEY_COLUMN ?
Oh, it would be usefull for sure, but that's not exactly what I meant. I
meant that each command that creates a vector map with a linked table
should allow for specifying the key column name at it's runtime. Having
such functionality *and* a global variable for a default, would be
optimal.
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:4>
