[GRASS-dev] Re: [GRASS GIS] #293: wxGUI should provide a switch for
region-constrained/free display mode
trac at osgeo.org
Sat Sep 6 17:12:34 EDT 2008
#293: wxGUI should provide a switch for region-constrained/free display mode
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by martinl):
Replying to [comment:1 mlennert]:
> Now, maybe the fact that in the wx gui you can show the extent of the
computational region solves this issue (although it doesn't solve the
resolution issue raised in #106), I'll just have to work with it a bit
more to really find out, but up to now I have found the absence of the
constraint mode a nuisance...
Helps?
Map display status bar ->
"Display mode"
Check "Constrain display resolution to computational settings"
Re-render
Untested, Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/293#comment:2>
