[GRASS-dev] doxygen problem - Re: [GRASS-SVN] r33243 - grass/branches/develbranch_6/lib
Markus Neteler neteler at osgeo.org
Sun Sep 7 04:28:01 EDT 2008
On Fri, Sep 5, 2008 at 10:28 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2008/9/5 Martin Landa <landa.martin at gmail.com>:
>> 2008/9/5 Markus Neteler <neteler at osgeo.org>:
>>> OK. The problem is that
>>>  "vector: Vector_Library (GRASS Vector and Direct Graph Library)"
>>> is no longer expanded as link. Someone just asked me if the
>>> vector lib is not documented and I discovered that the link is
>>> no longer generated at all. I just tried a fix but it isn't expanded...
>> it should be
>> <li>%vector:    \ref Vector_Library (GRASS Vector and Direct Graph Library)
>> see
>> lib/vector/vectorlib.dox
>> the page is called Vector_Library.
> I reverted the changes in r33271
> make htmldocs-single
> builds programmer manual properly on my machine.
Not so on grass.osgeo.org...:
http://download.osgeo.org/grass/grass6_progman/main.html
Could it be the doxygen version (the server has 1.5.1)?
Markus
