[GRASS-dev] Re: doxygen problem - Re: [GRASS-SVN] r33243 -
grass/branches/develbranch_6/lib
Markus Neteler
neteler at osgeo.org
Sun Sep 7 06:55:26 EDT 2008
On Sun, Sep 7, 2008 at 12:24 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2008/9/7 Markus Neteler <neteler at osgeo.org>:
>>> make htmldocs-single
>>> builds programmer manual properly on my machine.
>> Not so on grass.osgeo.org...:
>> http://download.osgeo.org/grass/grass6_progman/main.html
>> Could it be the doxygen version (the server has 1.5.1)?
> I am using 1.5.6, anyway, if you replace '%vector' by 'vector' link to
> Vector_Library appears?
Ah, on the server I found a local change:
--- vector/vectorlib.dox (revision 33309)
+++ vector/vectorlib.dox (working copy)
@@ -1,4 +1,4 @@
-/*! \page Vector_Library GRASS 6 Vector Architecture
+/*! \mainpage Vector_Library GRASS 6 Vector Architecture
I have reverted that and set it to the SVN version.
In ~1h from now we can check again:
Hopefully now solved.
Markus
