[GRASS-dev] Re: [GRASS GIS] #274: vdigit: cursor and vertex are apart when moving vertices
GRASS GIS trac at osgeo.org
Sun Sep 7 08:20:30 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by msieczka):
 Replying to [comment:5 martinl]:
 > I don't see this behaviour as a bug. Try to confirm action, vertex is
 moved properly. Standard use
 >  * left down to select feature or vertex
 >  * left up
 >  * move pointer
 >  * right up to confirm
 > or use 'apart'
 >  * move pointer
 >  * left up
 >  * move
 >  * confirm
 Such an "apart mode" should not be possible IMO. What would be the use for
 it? It only confuses the user.
 Could GUI take care of that so that both use ways would work the same?
 And still, even with the "standard use mode", if one moves mouse cursor
 right after selecting a vertex, there is a high likelihood the vertex and
 cursor become apart. This defect will bring troubles to folks with a fast
 hand. Digitizers in commercial setups will not be attracted to GRASS for
 that.
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:6>
