[GRASS-dev] Re: [GRASS GIS] #290: use a different default for wxGUI
displays
trac at osgeo.org
Sun Sep 7 09:32:16 EDT 2008
#290: use a different default for wxGUI displays
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):
Hamish:
> > screenshot of what you mean please.
Replying to [comment:2 msieczka]:
> Just add a scalebar or legend with labels in wxGUI display to see that
letters
> look bad if you don't change the default font.
There is no wx2.8 for Debian/stable and so I can not yet run wxGUI
locally.
Hopefully that will be solved in the next month with the upcoming Lenny
release.
I would like to see from the screenshot if the default you speak of is the
romans
stroke font or another, if it looks the same as in an old xmon or
different/worse,
and if it renders differently on your machine than on others.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/290#comment:3>
