[GRASS-dev] Re: issues with compiling and running GRASS on Mac
Michael Barton
michael.barton at asu.edu
Mon Sep 8 00:55:53 EDT 2008
Forgot to mention that I tried compiling wxnviz WITH render.h and got
the same errors.
Michael
On Sep 7, 2008, at 8:47 PM, Michael Barton wrote:
> cd /Users/cmbarton/grass_dev/grass6_src/lib/nviz
> make
> /Frameworks/UnixImageIO.framework/unix/include -I/Users/cmbarton/
> grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-
> apple-darwin9.4.0/render.o -c render.c
> render.c: In function ‘Nviz_create_render_window’:
> render.c:139: warning: assignment makes pointer from integer without
> a cast
> render.c:146: warning: assignment makes pointer from integer without
> a cast
> render.c: In function ‘Nviz_make_current_render_window’:
> render.c:204: error: ‘mac_win’ undeclared (first use in this function)
> render.c:204: error: (Each undeclared identifier is reported only once
> render.c:204: error: for each function it appears in.)
> render.c:204: warning: ‘AGLDrawable’ is deprecated
> make: *** [OBJ.i386-apple-darwin9.4.0/render.o] Error 1
