[GRASS-dev] adding thematic modules to makefiles
Mon Sep 8 05:19:41 EDT 2008
Michael Barton wrote:
> In develbranch_6, is there any reason NOT to add arraystats to ../lib/
> Makefile, v.class to ../vector/Makefile, or d.thematic.area to ../
> display/Makefile?
> I can do this, but want to make sure that there is not a problem in
> doing so.
Nope. The worst that can happen is that those directories fail to
compile. It shouldn't be able to cause anything else to fail.
