[GRASS-dev] suggested temporary feature freeze for wxGUI
Martin Landa
landa.martin at gmail.com
Mon Sep 8 05:28:09 EDT 2008
2008/9/8 Glynn Clements <glynn at gclements.plus.com>:
> gcmd.py:477:class CommandThread(Thread):
> goutput.py:48:class CmdThread(threading.Thread):
It's used for running GRASS command in own thread to update GUI
widgets properly (print module messages to log widget when the command
is running).
> mapdisp.py:84:class Command(Thread):
This not used currently.
> nviz_mapdisp.py:45:class NvizThread(Thread):
Not fully working, reason is the same as for CommandThread.
> histogram.py and vdigit.py also import the Thread class, but they
> don't actually use it.
For vdigit.py I was planning to implement same as for nviz_mapdisp.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
