[GRASS-dev] "Incompatible library version" errors
Markus Neteler
neteler at osgeo.org
Tue Sep 9 11:33:34 EDT 2008
On Tue, Sep 9, 2008 at 12:10 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> This:
> http://trac.osgeo.org/grass/changeset/33327
> - G_fatal_error(_("Incompatible library version for module"));
> + G_fatal_error(_("Incompatible library version for module: recompilation needed."));
> isn't necessarily accurate.
> The error could also be caused by a mismatch between PATH and
> LD_LIBRARY_PATH (or ld.so.cache, etc) if you have more than one
> version of GRASS installed.
> Or it could be caused by a module linking against GDAL, where GDAL was
> built against an old version of GRASS. In that case, it's true that
> recompilation is needed, but it would be GDAL that needs
> recompilation.
> In general, error messages should only report what is known; they
> shouldn't attempt to guess as the underlying cause.
Ah, I wasn't aware of all those other possibilities.
I only found the original message too minimalistic.
> E.g. if write() fails, then you know that write() failed. You don't
> know that it was due to insufficient disk space unless errno is set to
> ENOSPC. write() can also fail with EDQUOT (quota exceeded), EFBIG
> (maximum size of a single file exceeded), EIO (low-level I/O error,
> e.g. media fault, failed NFS server), and others.
Sure but in this case there are ENOSPC, EDQUOT etc. (so indications
could be trapped).
Anyway, I have reverted it.
Markus
