[GRASS-dev] [GRASS GIS] #305: Add created map into layer tree:
errors for import modules
trac at osgeo.org
Tue Sep 9 16:26:39 EDT 2008
#305: Add created map into layer tree: errors for import modules
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
1. in preferences set "Add created map into layer tree"
2. try to import using any module, in GUI, = errors
For example, 'v.in.ogr dsn=pomiar.shp output=pomiar' yields:
Execution failed: 'd.vect map=pomiar at podklady --q'
Details:
Error: Vector map <pomiar at podklady> not found
Moreover, re-running the command with ovewrite will add the layer again
(so after 2 re-runs you have the layer twice on the list, and so forth).
Could this be avoided?
Ticket URL: <http://trac.osgeo.org/grass/ticket/305>
