[GRASS-dev] Re: [GRASS GIS] #307: v.in.dxf: output name should be
required
trac at osgeo.org
Tue Sep 9 17:06:22 EDT 2008
#307: v.in.dxf: output name should be required
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Changes (by martinl):
* cc: martinl (added)
Comment:
Name of output vector map can be determined from input file name, e.g.
file.dxf become 'file' vector map if output parameter is not given.
It was changed in GRASS7 where output is required. I would suggest leave
v.in.dxf in GRASS6 as it is.
Ticket URL: <http://trac.osgeo.org/grass/ticket/307#comment:1>
