[GRASS-dev] Re: [GRASS GIS] #306: v.in.ogr GUI is missing --o and
--v
trac at osgeo.org
Thu Sep 11 21:17:50 EDT 2008
#306: v.in.ogr GUI is missing --o and --v
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:12 neteler]:
> I got traped byt this also a few times and overlooked the horizontal
scroll arrows on the right. Any ideas to make that more outstanding? Eg. a
half-shown/grey tab on the right (one of those which don't fit) would make
it obvious I guess. Would that be possible?
The behaviour is dictated by the underlying widget provided by the
toolkit, e.g. GtkNotebook for wxGTK. It may be possible to modify the
appearance using the mechanisms provided by the toolkit, e.g. themes or
gtkrc.
You could use e.g. wxChoiceBook (which uses an option menu instead of
tabs) instead. The only other alternative is to construct the equivalent
of wxNotebook from the base widget classes (e.g. wxPanel, wxButton).
Ticket URL: <http://trac.osgeo.org/grass/ticket/306#comment:13>
