[GRASS-dev] Re: GRASS-dev] wxGUI vedit dropped
Michael Barton
michael.barton at asu.edu
Thu Sep 11 21:38:22 EDT 2008
On Sep 10, 2008, at 11:36 PM, <grass-dev-request at lists.osgeo.org> <grass-dev-request at lists.osgeo.org
> wrote:
> Message: 7
> Date: Thu, 11 Sep 2008 08:11:03 +0200
> From: "Martin Landa" <landa.martin at gmail.com>
> Subject: [GRASS-dev] wxGUI vedit dropped
> To: "GRASS developers list" <grass-dev at lists.osgeo.org>
> Message-ID:
> <f8fe65c40809102311x71cc928cxcdf22ae053ed8870 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> currently you can choose from two components of vector digitizer --
> vedit and vdigit. Vedit calls directly v.edit command which slows down
> every action, Vdigit uses C++ extension. Vedit component has been part
> of the development. It this moment I would suggest to drop this
> component. At the end code will be more readable and only one
> component will be tested.
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/vdigit.py#L242
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/vdigit.py#L783
> If you agree I will remove vedit component during next week.
> Martin
Martin,
I agree with this plan. BUT this makes it more imperative than ever to
get vdigit to compile and run correctly on platforms other than Linux.
Currently, it compiles against the system version of Python rather
than the newer default one that I have, so I have to disable it or the
wxPython GUI won't even run. I've never been able to test it on a Mac.
I don't know what its status is on Windows. I realize that such cross-
platform issues are sometimes very tricky and hope that you can
continue to get some help on this.
Michael
