[GRASS-dev] Re: [GRASS GIS] #306: v.in.ogr GUI is missing --o
and --v
Michael Barton
michael.barton at asu.edu
Fri Sep 12 01:16:54 EDT 2008
On Sep 11, 2008, at 7:29 PM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Fri, 12 Sep 2008 01:17:50 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> Subject: [GRASS-dev] Re: [GRASS GIS] #306: v.in.ogr GUI is missing --o
> and --v
> To: undisclosed-recipients:;
> Message-ID: <051.14e06d18c5be85e3da50d7f0014ccb9f at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
> #306: v.in.ogr GUI is missing --o and --v
> Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
> Type: enhancement | Status: new
> Priority: major | Milestone: 6.4.0
> Component: wxGUI | Version: svn-develbranch6
> Resolution: | Keywords:
> Platform: All | Cpu: All
> Comment (by glynn):
> Replying to [comment:12 neteler]:
Thanks for the suggestions.
>> I got traped byt this also a few times and overlooked the horizontal
> scroll arrows on the right. Any ideas to make that more outstanding?
> Eg. a
> half-shown/grey tab on the right (one of those which don't fit)
> would make
> it obvious I guess. Would that be possible?
These are built into the controls and not easily changed. The
flatnotebook control used has a better selection of special items to
add to tabs (arrows, close boxes, etc) than most other notebook
controls). Making the window scale dynamically is a potentially more
feasible option.
> The behaviour is dictated by the underlying widget provided by the
> toolkit, e.g. GtkNotebook for wxGTK. It may be possible to modify the
> appearance using the mechanisms provided by the toolkit, e.g. themes
> or
> gtkrc.
This needs to work cross-platform
> You could use e.g. wxChoiceBook (which uses an option menu instead of
> tabs) instead.
This gives a vertical row of icons instead of horizontal tabs. It also
takes up a lot of space in the control windows.
> The only other alternative is to construct the equivalent
> of wxNotebook from the base widget classes (e.g. wxPanel, wxButton).
I don't think we want to get into that. It's a lot of work and
requires a lot of expert knowledge of wxPython to build and especially
maintain.
Michael
