[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building
python swig
trac at osgeo.org
Fri Sep 12 04:03:31 EDT 2008
#308: Compiler error while building python swig
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: SWIG (all bindings) | Version: svn-develbranch6
Resolution: | Keywords: python swig
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
I checked in some fixes to devbr6 SVN but it still doesn't build.
python_grass6_wrap.c: In function '_wrap_Cluster_nbands_set':
python_grass6_wrap.c:48044: error: dereferencing pointer to incomplete
type
python_grass6_wrap.c: In function '_wrap_Cluster_nbands_get':
python_grass6_wrap.c:48067: error: dereferencing pointer to incomplete
type
python_grass6_wrap.c: In function '_wrap_Cluster_npoints_set':
python_grass6_wrap.c:48097: error: dereferencing pointer to incomplete
type
python_grass6_wrap.c: In function '_wrap_Cluster_npoints_get':
python_grass6_wrap.c: In function '_wrap_new_Cluster':
python_grass6_wrap.c:49087: error: invalid application of 'sizeof' to
incomplete type 'struct Cluster'
python_grass6_wrap.c: At top level:
python_grass6_wrap.c:82965: warning: function declaration isn't a
prototype
make: *** [python_grass6_wrap.o] Error 1
Auto-generation of gis.i seems to be an important thing, so wrt to
tackling that next:
- gis.i seems to be based on gis.h circa 12/17/04 (r16393)
After removing comments and trailing whitespace, then diff'ing versus
gis.h r16393 the changes between gis.h and gis.i are as follows:
-extern CELL CELL_NODATA;
+/*extern CELL CELL_NODATA; Sajith */
@@ -159,10 +101,17 @@
unsigned char red;
unsigned char grn;
unsigned char blu;
- } low, high;
+ } high;
+ struct
+ DCELL value;
+ unsigned char red;
+ unsigned char grn;
+ unsigned char blu;
+ } low;
- struct _Color_Rule_ *next;
- struct _Color_Rule_ *prev;
+/* struct _Color_Rule_ *next;
+ struct _Color_Rule_ *prev; Commented By sajith I am confued
here....*/
struct _Color_Info_
The duplication of the high,low structs was done by Sajith AFAICT.
I've no idea why of course, but that's what it is.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:11>
