[GRASS-dev] Re: r.external
Glynn Clements
glynn at gclements.plus.com
Fri Sep 12 20:59:02 EDT 2008
Markus Neteler wrote:
> > r.info -r pat_dtm_5m
> > WARNING: category support for [pat_dtm_5m] in mapset [PERMANENT] missing
> > min=nan
> > max=nan
> I observe that 'f_range' remains empty:
> GRASS 6.4.svn (patUTM):~ > l
> /home/neteler/grassdata/patUTM/PERMANENT/cell_misc/pat_dtm_5m
> total 52
> -rw-rw-r-- 1 neteler neteler 132 2008-09-12 14:07 gdal
> -rw-rw-r-- 1 neteler neteler 0 2008-09-12 14:07 f_range
> -rw-rw-r-- 1 neteler neteler 5 2008-09-12 14:07 f_quant
> -rw-rw-r-- 1 neteler neteler 28 2008-09-12 14:07 f_format
> -rw-rw-r-- 1 neteler neteler 39928 2008-09-12 22:16 histogram
Odd.
> Could the file be populated using GDAL functions?
It is:
304 info->range[0] = GDALGetRasterMinimum(hBand, &bGotMin);
305 info->range[1] = GDALGetRasterMaximum(hBand, &bGotMax);
306 if(!(bGotMin && bGotMax))
307 GDALComputeRasterMinMax(hBand, !exact_range, info->range);
460 struct FPRange fprange;
461 fprange.min = info->range[0];
462 fprange.max = info->range[1];
463 G_write_fp_range(output, &fprange);
464 write_fp_format(output, info);
465 write_fp_quant(output);
The fact that the f_quant and f_format files are being written implies
that G_write_fp_range() is being called, but is writing an empty file.
Hmm; the -r flag won't help if GDAL is reporting a stored range. But
r.support.stats should fix that.
Is it possible that something is causing GDAL to "see" NaNs?
Maybe the presence of NaNs interferes with the range calculation. As
all inequalities return false for NaN, code such as:
#define MIN(a,b) ((a) < (b) ? (a) : (b))
#define MAX(a,b) ((a) > (b) ? (a) : (b))
for (i = 0; i < n; i++) {
min = MIN(min, x[i]);
max = MAX(max, x[i]);
will set both min and max to NaN if even a single x[i] is NaN.
