[GRASS-dev] getting vdigit to compile correctly on the Mac
Michael Barton
michael.barton at asu.edu
Sat Sep 13 14:27:07 EDT 2008
Thanks William,
I'll give these a whirl and report back.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Sep 13, 2008, at 10:20 AM, William Kyngesburye wrote:
> On Sep 13, 2008, at 10:54 AM, Michael Barton wrote:
>> Here is a link to discussion that may help explain why vdigit is
>> not compiling correctly on a Mac--especially with OX X 10.5
>> (Leopard) that comes with Python 2.5--and a couple of solutions to
>> fixing it.
>> http://mail.python.org/pipermail/pythonmac-sig/2008-January/019628.html
> I've suggested distutils before. It just needs someone to write the
> setup.py script.
> Also, your problem may be a bit different - it may be configure
> that's messing up. Are the python flags in your platform.make
> pointing to the system python or the python.org python?
> Configure uses python-config to get the configuration of python
> includes and libs. If you just say "--with-python" (as I have in
> the example in the GRASS OSX readme) configure will try to find it
> in your PATH, and may be getting it wrong.
> Try setting a path to python-config when configuring. It should be /
> usr/local/bin/python-config (symlinks installed by python.org
> installer). ie:
> --with-python=/usr/local/bin/python-config
> If configure is getting it right and it's still messing up the
> linking, another possibility is that the python.org python doesn't
> install lib symlinks in /usr/local/lib, so even though the library
> path is specified it may get the system python from /usr/lib. It's
> not supposed to, but I've seen it happen with the system sqlite vs.
> my sqlite framework (though not recently, maybe the new Xcode has
> fixed this).
> I could try it, but I don't want to mess up my MacBook by installing
> (for real) the python.org python (I like the system python), though
> I could try it on my Mini.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin] You think you have problems? What are you supposed to do
> if you ARE a maniacally depressed robot? No, don't try and answer,
> I'm 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
