[GRASS-dev] vdigit error -- more info
Michael Barton michael.barton at asu.edu
Sun Sep 14 01:57:45 EDT 2008
On Sep 13, 2008, at 8:44 PM, William Kyngesburye wrote:
> On Sep 13, 2008, at 5:45 PM, Michael Barton wrote:
>> Now that William's worked out a way to compile vdigit on the Mac
>> (should this be committed or there a risk of breaking another
>> platform?),
> It shouldn't affect other platforms.
>> I can move ahead and report actual errors in using vdigit. Sorry
>> that I don't know how to fix these.
>> Anyway, whenever I select a vector to edit (including creating a
>> new vector for editing), I get the following in a wxPython
>> MessageBox:
>> Vector digitizer error
>> Unable to initialize display driver, see README file for more
>> information
>> Details: 'NoneType' object has no attribute 'OpenMap' (dlopen(/
>> Applications/Grass/GRASS-6.4.app/Contents/MacOS/etc/wxpython/vdigit/
>> _grass6_wxvdigit.so, 2): Symbol not found: _Vedit_add_vertex
>> Referenced from: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/
>> etc/wxpython/vdigit/_grass6_wxvdigit.so
>> Expected in: dynamic lookup
>> Michael
> It looks like it didn't link to the vedit lib.
> So I can check myself: how do you start vdigit?  Is it "Digitize" in
> the display window or right-click the layer and "start editing" or
> something else?
I get the same results when I start it either way.
Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
