[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Sun Sep 14 15:22:55 EDT 2008
Typo fixed.
Recompiled (did make distclean between each compilation just to make
sure that nothing lurking in a previous build could cause a problem)
using: --without-x --without-tcltk AND --with-x --without-tcltk
Still no go. I'm attaching crash logs. I am also noticing that every
make and make install causes a r.terraflow crash--even though I've not
launched r.terraflow. I'm not sure what this is about, but note that
the problematic wxPython modules and r.terraflow all use C++.
I'm attaching the r.terraflow crash log too, in case it holds a clue.
Michael
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080914/5d0ff0ae/Python_without-x_without-tcltk-0001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080914/5d0ff0ae/Python_with-x_without-tcltk-0001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080914/5d0ff0ae/r.terraflow_2008-09-14-121541_cmb-MBP-2-0001.obj
On Sep 14, 2008, at 11:36 AM, William Kyngesburye wrote:
> On Sep 14, 2008, at 1:22 PM, Michael Barton wrote:
>> I went ahead and installed PyOpenGL, recompiled ../lib/nviz and ../
>> wxpython/nviz.
> Nothing binary in PyOpenGL, so no need to recompile.
>> Same result. I'm glad that you're getting partway there on the
>> Mini, but not sure what else I need to do to duplicate your setup.
>> I'm including my compile ritual below for comparison. Note, I AM
>> building the TclTk GUI too, but that shouldn't matter.
>> Michael
>> export CFLAGS="-arch i386 -Os -g"
>> export LDFLAGS="-arch i386 -Os -g"
> If below doesn't help, try without the -g flag?
>> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.8.1/bin/wx-
>> config --with-wxwidgets=/usr/bin/wx-config
> Um, you should only use the /usr/local one.  I'm guessing that the
> 2nd --with-wxwidgets completely overrides the first.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
