[GRASS-dev] Re: [GRASS GIS] #64: ps.map: patch to set customized scalebar units
GRASS GIS trac at osgeo.org
Sun Sep 14 20:27:11 EDT 2008
  Reporter:  alf          |       Owner:  hamish
      Type:  enhancement  |      Status:  closed
  Priority:  minor        |   Milestone:  6.4.0
 Component:  ps.map       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  scalebar
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 (related)
 I have added some code to ps.map's floating point (smooth) colortable
 legend which will print a label for the map's data units if present.
 Data units can be set with r.support.
 I am not very happy with the x placement. The offset to the right is
 currently based on the length of the tick labels and the fontsize, but as
 the fonts are proportional width and the fontsize is based on the font
 height, it's a bit of a fudge. It's too close for small numbers and too
 far away for large numbers.
 I don't know if it is possible to get the right-hand coordinate of a PS
 pseudo-text box when the text is left-justified. I do not wish to right-
 justify those labels.
 I suppose the answer is to derive some function of max_label_length, but I
 fear that will only hold for the default font=Helvetica.
 Or move the label above/below the legend.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/64#comment:9>
