[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Mon Sep 15 00:59:57 EDT 2008
Here is where the files are bombing. I can test this with vdigit. I
suspect that it fails for the same general reason that nviz fails.
In vdigit.py, it bombs at importing grass6_wxvdigit and goes to the
exception.
Michael
try:
digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
sys.path.append(digitPath)
import grass6_wxvdigit as wxvdigit
GV_LINES = wxvdigit.GV_LINES
digitErr = ''
except ImportError, err:
GV_LINES = None
digitErr = err
# print >> sys.stderr, "%sWARNING: Digitization tool is
disabled (%s). " \
# "Detailed information in README file." % \
# (os.linesep, err)
On Sep 14, 2008, at 5:38 PM, William Kyngesburye wrote:
> On Sep 14, 2008, at 6:26 PM, Michael Barton wrote:
>> It's definitely a compile issue. Your version works just as you
>> describe it--AND vdigit works too.
> hmmmmm
> rrrrgggghhhh
> The only other thing I can think of that I do a little different is
> maybe the OSX build target. I set the MACOSX_DEPLOYMENT_TARGET to
> 10.5 (or 10.4 for my Tiger builds). The default is 10.2 or 10.3 I
> think. There are some differences in compilation depending on this
> value, though I think it's mostly API differences not compiler
> behavior. Python code wants you to match what was used when it was
> compiled, which is 10.4 for Macpython (though I didn't have problems
> on my Mini build).
> Try:
> export MACOSX_DEPLOYMENT_TARGET=10.5
> before configuring
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
