[GRASS-dev] scale and offset in raster maps
andrea antonello
andrea.antonello at gmail.com
Mon Sep 15 09:04:18 EDT 2008
Hi Hamish,
thanks for your answer.
I just wanted to know if the internal GRASS binary format has this
metadata inside. At that point I guess that the answer is no?
Thanks,
Andrea
On Mon, Sep 15, 2008 at 2:59 PM, Hamish <hamish_b at yahoo.com> wrote:
> Andrea antonello wrote:
>> I'm not talking about resampling, btu instead of threating of a single
>> value. In scientific data often you could store integer maps for
>> several reasons and there is an offset and scale value that have to be
>> applied to get the usable physical floating point value of the map.
>> Scale and offset are defined in formats as for example netcdf and I
>> thought I saw this also in GRASS in the past.
> see http://grass.osgeo.org/wiki/MODIS#Processing
> http://grass.osgeo.org/wiki/MODIS#Processing_3
> etc.
> Hamish
