[GRASS-dev] nviz compile errors on Mac OS X
William Kyngesburye
woklist at kyngchaos.com
Mon Sep 15 09:39:50 EDT 2008
On Sep 15, 2008, at 3:05 AM, Glynn Clements wrote:
> William Kyngesburye wrote:
>>>> In addition to the other macpython + wx I mentioned, I installed
>>>> PyOpenGl 3.0.0b5.
>>> This shouldn't be necessary to run OpenGL but maybe Martin is using
>>> it for something.
>> nviz wouldn't run without it.
> Huh? What happens when you try?
I get an error that tells me I need it. It comes from a try/except
block in gui_modules/nviz.py.
> Glynn Clements <glynn at gclements.plus.com>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
