[GRASS-dev] Re: Problem when loading GRASS 6 raster with large
integer values into R via r.out.bin
Rainer M Krug
r.m.krug at gmail.com
Thu Sep 18 04:21:19 EDT 2008
On Wed, Sep 17, 2008 at 10:49 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Markus Neteler <neteler <at> osgeo.org> writes:
>> On Tue, Sep 16, 2008 at 6:50 PM, Rainer M Krug <r.m.krug <at> gmail.com> wrote:
>> > Hi
>> > I have a problem with importing raster maps of type CELL into R -
>> > larger values become "wrapped" around as r.out.bin saves the raster
>> > values as shortint values. Is there any possibility to change that
>> > behaviour, or at least convert the exported values automatically from
>> > integer to float?
>> My suggestion to Roger was to change to r.out.gdal:
>> http://lists.osgeo.org/pipermail/grass-stats/2008-June/000799.html
>> Since the GRASS-R interface knows the GRASS version it could be
>> conditionalized upon GRASS >= 6.3.0 for r.out.gdal, r.out.bin otherwise.
> The actual suggestion was not to use r.out.gdal, but to use the GRASS GDAL
> plugin if present. Then readRAST6() would use readGDAL() to read the
> raster directly if possible, using the GRASS plugin driver. This avoids
> creating a temporary file, but could be used directly from readGDAL() -
> it just sets up the correct path and file name.
>> Something has been implemented but it needs/ed to be activated
>> by setting parameters (at least in June, didn't check later).
> At present with default plugin=NULL, readRAST6() checks the list of drivers
> and if "GRASS" is present, and if the current and raster file regions agree,
> and only one raster is requested, it imports the raster directly into a
> SpatialGridDataFrame object using readGDAL(). If Rainer's data are in a
> raster that has the same region as the current region, the plugin would
> solve the problem.
No - the raster is covering a larger area, and the current region
covers only a small area of the raster.
> I can look at using r.out.gdal for making the temporary file, but IIRC, it
> suffers from the region mismatch problem that r.out.bin solves by resampling
> on the fly.
> Hope this helps,
> Roger
>> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
