[GRASS-dev] Re: r.external
Glynn Clements
glynn at gclements.plus.com
Thu Sep 18 08:54:40 EDT 2008
Markus Neteler wrote:
> >> using the DTM map registered with r.external, I get sometimes (not sure on
> >> what it depends), a Segmentation fault:
> >> Program received signal SIGSEGV, Segmentation fault.
> >> [Switching to Thread 47745198216448 (LWP 24661)]
> >> 0x00002b6c8556ebcb in free () from /lib64/libc.so.6
> >> (gdb) bt
> >> #0 0x00002b6c8556ebcb in free () from /lib64/libc.so.6
> >> #1 0x00002b6c83f0c09b in G_free (buf=0x7c7c668c) at alloc.c:130
> >> #2 0x00002b6c83f112e5 in close_old (fd=8) at closecell.c:144
> > 143 if (fcb->cellhd.compressed)
> > 144 G_free(fcb->row_ptr);
> > The compressed field should always be zero.
> > r.external should always set it to zero in the cellhd file, and for a
> > map opened for read, the cellhd structure should contain exactly what
> > is in the file.
> This seems to be the case:
> [neteler at fep grassdata]$ cd patUTM32/PERMANENT/cellhd/
> [neteler at fep cellhd]$ cat pat_DTM_5m
> proj: 1
> zone: 32
> north: 5157086
> south: 5059541
> east: 730098
> west: 612488
> cols: 23522
> rows: 19509
> e-w resol: 5
> n-s resol: 5
> format: -1
> compressed: 0
So it appears that something is modifying fcb->cellhd.compressed.
But I have no idea what. For an input map, nothing explicitly modifies
that field after the structure has been read from the file, and I
can't see any plausible memory corruption scenario.
d.rast should only have a single raster open, so the preceding
G__.fileinfo[] slots should be unused (AFAICT, the fact that it's
getting fd=8 is due to additional descriptors used by gdb).
The only array in "struct fileinfo" is NULL_ROWS, but if the map is a
GDAL link, the only code which modifies that uses
"for (i = 0; i < NULL_ROWS_INMEM; i++)", so it can't overflow the
array.
