[GRASS-dev] r.contour - G_malloc:out of memory
Glynn Clements
glynn at gclements.plus.com
Mon Sep 22 09:13:03 EDT 2008
Henning Lorenz wrote:
> In Grass 6.3 on Mac OSX 10.5 I try to contour the following raster
> file (from r.info):
> Type of Map: raster Number of Categories: 255
> Data Type: CELL
> Rows: 38002
> Columns: 50276
> Total Cells: 1910588552
> Projection: UTM (zone 40)
> N: 7949005.04157202 S: 7816000 Res: 3.49994847
> E: 523000 W: 347033.98326284 Res: 3.50000033
> Range of data: min = 0 max = 255
> with the region set to the raster file (from g.region -p):
> GRASS 6.3.0 (NovZem(old)):~ > g.region -p
> projection: 1 (UTM)
> zone: 40
> datum: wgs84
> ellipsoid: wgs84
> north: 7949005.04157202
> south: 7816000
> west: 347033.98326284
> east: 523000
> nsres: 3.49994847
> ewres: 3.50000033
> rows: 38002
> cols: 50276
> cells: 1910588552
> The file size on disk is 1.22 GB. I have 8 GB RAM, whereof 5929 MB
> free when I execute r.contour on the command line. r.contour fails
> with the following message after reading in ca. 25% of the data
> (reproduceable):
> GRASS 6.3.0 (NovZem(old)):~ > r.contour --overwrite
> input=NovZem_S_highrres_red at enhanced output=NovZem_shoreline levels=1
> Reading data:
> r.contour(13162) malloc: *** mmap(size=405504) failed (error code=12)
> *** error: can't allocate region
> *** set a breakpoint in malloc_error_break to debug
> ERROR: G_malloc: out of memory
> This happens while 3020 MB memory are still free! On the other hand it
> means that r.contour used ca. 3 GB of memory for load ca. 300 MB of
> data from the disk, i.e. the whole 1.22 GB dataset would require ca.
> 12 GB of free memory.
> Is this behaviour expected?
Yes.
You have ~2G (2^31) cells. Each one is stored internally as a 64-bit
floating-point value[1], meaning that it would require ~16GiB of
memory.
Try reducing the region resolution.
Note that the file in question is compressed, and only uses 1 byte per
cell when decompressed.
[1] which is probably overkill; a 32-bit value would likely suffice.
However, that might still be problematic in this particular case,
depending upon how much memory is required for other purposes.
